float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Feb 20, 2007 5:27 pm
Well whenever a car doesn't run right/start, there are always 3 things to check, and do so in this order;
1. CHECK THE CODES ON THE ECU!!! This is exactly what they're there for!
2. If no codes check for fuel. With out fuel, there is no running.
3. If fuel, check for spark. If you have fuel and air, but no spark, then nothing goes kaboom and the engine doesn't run.
If you have no code, fuel, and spark, and the car doesn't start, then you did something wrong.
