p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sat Jul 05, 2003 1:50 pm
vacuum leak, idle control valve, or one cylinder thats not working at all, at higher speeds you wouldnt knotice it because theres enough momentum to cancel it out. try pulling spark plug wires ONE AT A TIME, the engine should get worse or die, thats a good thing. if you pull a wire and the engine still acts the same way then you got a problem there!!!! remember when you pull a wire put it back as you move on to the next one.
