aurora61 »
https://forums.nicoclub.com/aurora61-u42830.html
Mon Jan 29, 2007 8:15 am
i recently installed my tomei 2 way lsd...
However, my car seems to suddenly jerk while driving on straight-aways. This jerking is not constant, but suddenly happens every minute or so. This jerking seems to happen more on higher rpms (maybe around 2500 and up), and it usually becomes fine in the lower rpms...especially cruising in 5th gear. Also, flooring the clutch to shift gears suddenly jerks the car. (The car jerks more right than left if that matters)
The installation of the lsd seemed to go pretty well, and i went through the initial break-in procedure involving doing figure-8s. I also changed the diff oil after the break-in. Also the differential pumpkin has no leaks. The alignment does not look bad either.
So does anybody have any ideas to fix this problem?
