nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue Jan 08, 2013 6:43 pm
Rotors will will cause a shimmy if they are warped, sometimes bad if brakes are pressed hard. Tension rods don't necessarily have to be replace, you can buy poly inserts, which runs about $35. Very easy to put it, taking all the rubber out and the metal rings are the most difficult part.
Another thing you can look into, which I am having a similar issue is the the Master cylinder. It is possible that one of the o-rings are causing blow by which applies pressure to one side sooner than the other. Mine are odd, I can press the brakes lightly and all is fine, I press a little harder and I get a nasty pull to one side, I think driver. I press harder, the pull goes away. I rebuilt the calipers, flushed the system, ABS system is good, its the only thing that is left. This is for braking.
When you go over a bump and it still jerks to one side, you have an issue with the geometry, tension rods are mainly what I am thinking. If the steering rack bushings are bad, this could also cause an issue, especially with the steering wheel. Again, the poly bushings are the way to go, and only cost about $25. If the rack is covered in oil, this will deteriorate the rubber bushings extremely fast. This will also cause the steering wheel not to center after a turn.
