rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.html
Thu Oct 08, 2009 5:51 pm
before I even read the thread, after listening to the video, I knew oit was the battery...
for a while, I was runniogn my stereo system and all 8 TV's in the car while driving all the time... then one day, the car started wigging out... it sounded just like this one of the times, and I tested the battery and saw that my voltage was VERY low... I've since added a few more things to prevent this from happening (and yes this happened to my kinetik 1800)
if I were you, I would get a red top... yellow tops are for cars with large voltage draws like stereos ... deep cycle (gel cell)batteries are designed to be drained and recharged with no problems.... your factory acid filled batter is not, so after getting drained like that, it will NEVER be the same again... not that it won't fully charge, but it will never hold charge like it did before... they aren't designed to be discharged like that...
anyway, to be safe, I would get a red top.. those are just designed with a large amount od cranking amps and cold cranking amps and you'll never have to worry about batteries agin!
