car isn't starting. what am i missing?
karmakaze
Car: 98 240sx SE
engine turns over, i have spark. i have fuel. i took out my CAS and spun it by hand and i could hear my injectors fire, fuel pressure is around 43psi. i set #1 cylinder to TDC and verified the mark on the pully. and put the CAS back in @ the same place it was at before i swapped cams (i marked it) so the timming should be the exact same as before i tore everything apart.
What am i missing?
i also ran a 3rd ground to the engine to make sure that wasn't the problem and had my 240 jumped to another running car. all fuses are fine.
I am actually a little confused.
Modified by karmakaze at 5:03 PM 4/28/2006
xS13Sr240x
Car: 1991 s13 240sx Sr20det powered
Hey man the same thing is happening to me. I have no idea what it can be. I am running stock cams but it has seems i have done everything, but still not starting. I wish somebody could help me out.
karmakaze
Car: 98 240sx SE
ok, an update, double checked more stuff. TPS voltage is .45 and 4.2 wide open. i set it back to TDC and verified that the yellow dot on the CAS was lined up with the notch, and when i crank it over by hand i can hear the fuel going through the regulator so i would think that the CAS is functioning properly. i am gapped @ .28
i had to go back into work so that was the end of my attempt until tonight.
when i get home i am going to turn up the idle air a little bit and see if that makes a difference. other than seeing if it will go with some starter fluid i am out of ideas. *stumped* can anyone think of anything else that i should check?
anyone know if the ECU will still throw codes with the engine won't start up?
Modified by karmakaze at 5:24 PM 4/28/2006
sr20-thoj
Car: 89 nissan 240sx coupe
same thing happen to me.. just check the cas.. make sure its align right.. itll work.. I just kept playing with it.. and it worked..
tiger
swap ecu's.... btw... are you getting any codes?
double triple check your timing ;-) could be a tooth or so off...
karmakaze
Car: 98 240sx SE
i was setting my CAS to the wrong mark.
car runs great now. i am about to take it off of the stands and for a spin. only issue is the idle is lumpy and when i start it up the rpms drop and it wants to die but it catches itself. but i hear thats normal at first for HKS stage 1
