car is skipping!
turbinetech2
Car: 93 240sx se convertible!!
Hey guys, i have had this problem before on my old hatch. The car will start to skip while im driving and after checking the spark and changing the spark plugs it still tends to do it. I have changed the injectors before and it stopped and then started to do it again! If anyone has had this problem please let me know what it is!
Thanks!
Vegascorbin
Car: 1990 240sx dirt track race car
Not sure what you mean by "Skipping" (engine miss?) but have you changed the Cap and Rotor latly? How about plug wires? Does it happen only when low (or full) on fuel? Make sure you are up to date on fuel and air filter changes also.
tercel drifter
Car: sr20det s13
check spark plug gap and conditionspark plug wires fuel filtermaybe distributor cap idk
easy fix just put some elbow grease into it
turbinetech2
alrighty, ill change the fuel filter and and mess with the distributor. as far as how much gas i have im not totally sure. thanks for the help. if anyone else has any info hit me up
