car is running rich any idea's?
fast_s13
:help i have a 90 240sx with 67,000 mile's on it and it is running very rich. i have no mod,s done to the motor cause i am going to do a sr swap i just need to get it running good for summer
ricebike
2002 Quest
2005 Altima
just guesses...
leaking fuel injectors?
t-stat stuck open or temp sensor malfunction making the ECU think engine is still cold??
fast_s13
my injectors are leaking buut i think it might be the t-stat cause my heater dont blow hot thank for the help
yellow_jacket
Car: 95 240sx
Just curious, how do you know it is running rich?
fast_s13
air fuel ratio gauge....
Nismo_Freak
Car: 89 Nissan 240SX
Did it just start to do this? I've noticed KA's run a little rich on the top end. A better indication would be to pull your plugs and inspect them. If they are light brown then dont worry, if they are black or deep brown then you are definately over fueling. This would be due to your thermostat and leaky injectors. Also the non wideband A/f gauges arent very accurate. It may be a malfunction with your 02 sensor.
fast_s13
my car runs rich from start up all they way till i shut it off..........could it have something to do with having a hollow cat?
Nismo_Freak
No ... the primary 02 is located before the cat. It must be the injectors overfueling as a result of the thermostat or leaks.
fast_s13
why would leaky fuel injectors make it run rich?
Nismo_Freak
If they leak into the manifold they can cause an overly rich mixture.
fast_s13
i think im going to go pick up a new thermostst tomorrow and try that since my heater isnt working right anyway
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
I would also check your coolant temp sensor on your intake manifold. If the pigtail connection is green with corrosion, you need to replace it. If your coolant temp sensor is out, the ECU thinks the engine is cold and dumps extra gas into it, waiting for it to warm up.
fast_s13
i just repalced my o-rings on my fuel injectors and it didnt help any so next warm day i have im going to change the thermostat
sethulrich
Car: S13 240SX Fastback KA24DET - GTiR T28 + 550cc injectors + Z32 MAF + RS-Enthalpy tune
if the coolant temp sensor is out, will it make the check engine light come on? also, is there another way to check it besides seeing if it's green with corrosion?
