car is running cold
NotDave
Car: 96 240sx that needs paint
ever since the weather has become colder ive noticed that it takes longer for the car to warm up, normal stuff.
after driving about 45 mins i noticed that mt temp gauge is lower than it should be. normally its a few ticks under the halfway mark but it was very close to the bottom (C) when i was driving. i pulled over off the freeway and let it idle while i popped the hood and checked it out. then i noticed it went back up to normal again.
i checked the fluids and its full. i bleed for air bubbles too. it still runs colder than normal and i find that the heater isn't as hot as it was before.
any ideas?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
thermostat failed open?
DAEDALUS
Car: 1990 Infiniti Q45
Probably. Make sure the fan clutch isn't locked up too.
NotDave
well i think the thermostat still works b/c i unplugged it and i can see the gauge drop down to the bottom and when i plug it back in it rises again but it was still in the cold position.
the fan works, i see it start and stop
s13sr20chris
that was the thermal transmitter. the thermostat is a mechanical device inside your cooling system. it is easy to replace and only costs like $35 from a dealer.
Toahk
Car: 97 ....
its like 15 bucks from nissan.
