Car is only a 4 cylinder. Help!
M_ryder15
Car: 300ZX
Car is a 1990 Nissan 300ZX 2+2. Been sitting for about 3 years, before I bought it. Slowly fixing it, but recently been misfiring. 2 cylinders aren't working, and cannot figure out what it is. Check the spark plug (which I replace all of them a couple months ago) and look fine. Checked if there was power to the plugs, and it seems like every other plug, they're getting power. Changed the ignition coils, and still nothing. I'm still new to all of this, so any help would be appreciated. Thanks in advance
ca18det_boy
Try swapping coils to see if the problem follows. If the problem stays the same on the applicable cylinders, you're most likely looking at a break in the signal wire or the ECU isn't sending the right info.
M_ryder15
Car: 300ZX
ca18det_boy wrote:
Tue Mar 20, 2018 10:26 am
Will try. Thank you
NolimitZ32
Spark, Fuel, Compression. Confirm that you have each of the three, once you find whats missing go from there. Check the FSM in the link in my signature.
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
Does it sound like a subaru?
echonightsi
Car: 93 300zx N/A RED Current
93 300zx N/A BLK (SOLD 2011)
Vague, how many miles does it have on it? You still havent touched the injectors, which go bad over time.
