ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Sun Dec 27, 2009 5:44 pm
a pigtail is a term used to refer to the plug and a short length of wire used to connect it, i doubt it would short out the ecu....it may....but i doubt it, but if you need one ill sell you my extra one..... and your check engine light is probably on because your current maf is either damaged or that "chip''(cheap a** piece of junk resistor) has caused a fault, replace it clear the codes in your ECU(after you read them to be sure there arent any other faults) and give her another try
