Car is floaty and steering wheel is lose when at high speeds
smokin240
This isnt much of a problem when im in town but when im out on the highway or something, this gets sorta annoying.... any idea what causes this? I have a 93' 240sx.
SRdave240
alignment would be one common cause. I'd start with that. Otherwise, it could be any number of suspension problems.
candela
subframe buschings, TC rod buschings, Tie rod buschings, alignment <---- most common problems for that symptom
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
id bet a few bucks its the tie rod bushings
smokin240
its always done that, even right after alignment. Also, when it was inspected, one of the tie rods were missing so i had to get another one of those, but that parts fixed. ill check out the buschings, thanks.
