car is dead every morning... done some tests
bonestock240sx
Car: 1991 Nissan 240sx
1991 240sx
180xxx
not sure what the problem is but my car doesnt hold a charge more than about 24 hours.... trying to figure out why... my dad and i checked to make sure the battery charges and holds a charge.... and it does. we also tested if there was any draw on it... and there was practically none. obviously if we take the battery out it holds it charge but you put it back on it will die by morning time. No lights are being left on.
if anyone has anyideas let me know.
Thanks
Justin35ll
Car: s13 coupe sr20det
only way to find out is doing a parasidic drain test.
bonestock240sx
like i said we pretty much did the parasitic draw test... and there was less than a miliamp of draw which is practically nothing..... ill go do it again and make sure its all the same.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
My friends jeep was doing this and it was his door switch. I know mine was pretty f'd so I got some off a shell.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
How exactly were you doing the parasitic draw test?
bonestock240sx
with a voltmeter... i havent had a chance to do it. ive been pretty busy hopefully ill have time this weekend
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Load test the battery, there is always some current draw, but that much should not affect the battery unless its sitting a month or more. Take that battery and have it load tested.
bonestock240sx
i have a load tester and have tested the battery. the battery was good to go
Crazyirish
Car: Nothing noteworthy at the moment...
Start disconnecting subsystems and see if you can isolate it.
bonestock240sx
update:
problem is still occurring and i have gotten a new battery.... i did the light test (hook up a test light and see how long it takes to go out, which it goes out in about 30 seconds after the ecu power is taken away).... i've unhooked my sound system to see if i was just drawing more than my alternator could handle and that did nothing. everything is stock on the car especially relating to anything electircal. replaced the alternator about a year ago now.
my thoughts: the alternator did show a reading that says one of the diodes is bad... however when i talked to a guy my dad knows who deals with battery's and alternators he told us to do the light test (mentioned above) and if the light goes out then there is no bad diode.... honestly, however when testing for a bad diode and it give a bad reading on a voltmeter i would have to believe that the diode is bad. the theory of my dad as well as the other guy is that if there is any draw then the light will stay on. but it doesnt. like i said however the diode is reading bad on the alternator.
any thoughts on this?
zerepdivad
Yeah my thought is do a real parasitic draw test. not this mullet test light crap.
http://www.flashoffroad.com/electrical/ ... Drain.html
bonestock240sx
I have done a real draw test...... and.the light test.
zerepdivad
And your results were? actual NUMBERS...
bonestock240sx
i posted those earlier... they were less than a miliamp
zerepdivad
then you aren't testing right if you can actually unhook the battery and it doesn't die. you have a draw if it's dying overnight, and if you tested and got less than a milliamp of a draw then you aren't doing it right....
bonestock240sx
thank you for telling my battery will die over night if there is a draw.... i have done exactly what the article you posted said... and normally get less than a miliamp... somtimes its about 1-2 milliamps
bonestock240sx
or how about this.... .002 to point .010 amps... for more specific numbers sometimes im at about .015 amps
bonestock240sx
not to mention i have i have pulled every single fuse in the car. and the readings do not change.
zerepdivad
.002 amps is 2 milliamps, and .010 amps is 10 milliamps
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
bonestock240sx wrote:update:
Have you tried using a different alternator? If the diode reads bad, it will drain the battery.
bonestock240sx
I changed it out.about a year ago
Hoffman5982
Car: '95 sr20det 240sx
thats all good and well, but whether you changed the alternator a year ago or not, it now has a bad diode which means you might need to replace it again
bonestock240sx
Yeah I totally understand that.... but What I have been hearing Is that if that diode is truely bad then there should be a constant draw which would leave the test light on..... I'm gonna replace it no matter what. I'm trying to get other possible ideas as well in the event changing the alternator does nothing. And to zerepdivad no offence was meant with my sarcasm
