asymetric_ass_wear »
https://forums.nicoclub.com/asymetric-ass-wear-u171975.html
Sat Nov 06, 2010 8:26 am
I plan on bringing my car to the dealer or a local shop for the following issue. I plan on simply giving them this write up.
Has anyone experianced anything similar ?
I have a push button start on my 2008 altima coupe. The car requires the foot on the brake for the car to start.
Intermittently, the BRAKE, ABS, and SLIP lights come on. They come on when I am driving (not exactly sure when during driving, as I am not looking at the dash). They go off when I turn the engine off and then back on. This is intermitent but happens in bunches (happens frequently for a few days, then not at all for weeks). The brakes have been checked and they are/were OK when checked. There were also no engine failure codes stored.
Shortly after the brakes were checked for the above issue, the car would intermittently not start. usually trying over and over again the car would start. This was also intermittent, and seemed basically coincident with when the lights would come on while driving. (both intermittent problems would come and go together).
When the car wouldnt start, it behaved exactly as if my foot wasnt on the brake, even though it was. Specifically, the first time I pushed the start button, the ignition would go to the ACC indication, and the second time it would go the ON indication (but the engine is off).
Assumption at this point is that for whatever reason, the car didnt know my foot was on the brake, so it wouldnt start. In the rare instances when I couldnt get the car to start with repeated presses of the start button, the remote start would work. Note that the remote start doesnt require the foot on the brake.
Unfortunaalty, I was wating to get one additional piece of information before I took the car in. I finally got this piece and unfortunalty, it doesnt support the above theory.
Apparently the brake lights will go on even if the car is totally off when I put my foot on the brake. So I have gotten into the habit when starting the car at night to look in my rear view mirrow to see if the brake lights come on when I first get in the car.
So far, the car has failed to start once when I was checking the brake light. I didnt check it when I first hit the start button, but after I pressed the start button and the car didnt start, I checked the rear view mirror and the lights were OFF. I removed my foot from the brake, pressed it again, the brake light went on, and the car then started. (What I should have done was leave my foot on the brake, but press harder to see if that made the brake light go on, but I will do that next time. However, I dont think it is a pressure issue as when it doesnt start, I press it hard). With the above piece of information, everything hung together.
Then, the next time I got in the car, before even pressing the START button, I kept pumping the brakes to see the lights going on and off. I was hoping to see that on one of the brake presses, the light didnt come on.. This didnt happen, as the brake lights always came on. Then, when I pressed the START button, with the brake light on, the car failed to start. This one piece of information doesnt fit with the rest.
