zachattack_5491 »
https://forums.nicoclub.com/zachattack-5491-u101212.html
Mon Mar 29, 2010 12:27 pm
I have a redtop SR, and I've been trying to figure out what's going on with it for quite a while now. I'm extremely confused, so any input would be appreciated.
-I'm running super rich, black smoke and fuel shooting from exhaust.-Car has trouble reving up to 3000rpm, and will not go any higher.-When I first put it in, I was getting trouble codes for ignition, MAF, CAS, and knock sensor.-Knock sensor was fixed, CAS was throwing codes because it was unplugged to prime the engine before first startup, ignition was throwing codes because it was unplugged.-MAF just fixed itself I guess. I tested power, ground, and signal to the ECU... plugged it in... and the code went away.
Now I know for sure that my o2 sensor is dead. But I've heard that the o2 would not send me into limp mode. Everything is leading me to believe the MAF is the culprit, but I'm not getting any trouble codes for it. Anyone have any opinions?
Modified by zachattack_5491 at 4:10 PM 4/9/2010
