car idles rough on cold mornings...check engine light??
starfireS14
i have a s13 blacktop in my 97 s14 on very cold mornings like 45 or less when i start it idles really rough. lots of smoke i figured out thats its running rich but i dont understand why it does that on cold mornings. I rev it up for about 5 mins and it runs ok. Im going to change the plugs Im not sure if thats the problem. Also i had Swap done and no check engine light comes on. Is there someway to hook that back up?
quiksilvia
Car: 95 s14 se
i wanna say thats the aiv valve, but i may be wrong...
slow s13
Car: cars, photo, music
yeah hook up pin 24 on the ecu conector to the red wire on the ecu sub conector that goes to the dash, you will probly need to get a pin from a nissan ecu conector at the junk yard, there is no pin in the 24 slot, I got one out of a 240 at the junk yard. If you search there should be some more info.
goldollar
Car: cars
Will your car pass emissions, seing how its an obd2 car with a japanese ecu. im just curious, Tryin to figure out wether to buy a obd1 car or an obd2 car.
starfireS14
goldollar wrote:Will your car pass emissions, seing how its an obd2 car with a japanese ecu. im just curious, Tryin to figure out wether to buy a obd1 car or an obd2 car.
I'm not even sure I have til August of next year til I do emissions will have to figure out something by then. I may be moving to FL anyway so not sure yet.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i've noticed that my car stutters a bit when i start it on cold mornings and just run it immediately. what's happening ( i think) is that the turbo isn't able to compress air effeciently until it warms up, so the car begins to stutter (especially between shifts). once it warms, it's ok. also, the idle is high during the first few minutes. i run around 1500-2000 on the tach until the car warms up and drops back down to 1000. that just signals to me that the car is trying to get more air by idling higher at start up.
