Chris-H wrote:Then it got in the mode where it would start, but the rpm would run down to 0 unless you held your foot on the gas peddle. Manually holding the gas peddle down for 5-10 seconds to keep it at 2500 rpm, then letting go did the trick.
I had a very similar problem when I bought my 90Q with 222k miles. It would search up and down between 1500rpm to 0rpm, sometimes stalling, before settling in at 650rpm and running fine.
The car had been sitting for over a year and had radiator spray on the engine. All the electrical connections had some level of corrosion. Cleaned them up with a toothbrush and brake parts cleaner, coated the pins in dielectric grease, and the engine purred.
Take a look at these connections: MAF, CAS, TPS, EGR solenoid, and the #1 and #2 injectors. Tighten up the female pins for a good tight fit, especially the MAF connection. This is a simple DIY that won't take longer than an hour. Good luck.
