SrSLeePeR »
https://forums.nicoclub.com/srsleeper-u316.html
Wed Nov 27, 2002 11:07 pm
Well...My car is hessitating for some reason.
I changed my fuel pump, fuel filter, and spark plugs and it still hessiates..Example:
Ill start off and if I give it gas, the car will not move, and a second later it'll start working normally if I step on it harder, as if there was lag at the throttle. When RPM's are high it's fine. When I floor it, it's fine. But when I'm driving normal, there's hessitation and lag.
Also, when I'm at idle, RPM's seem to rise and fall continuously from 400-1300 back and fourth every couple seconds.
All coils are fine but it seems as if when driving "normal", the motor doesn't get enough fuel and/or spark but all cylinders are firing and fuel pressure is perfect.
Does anyone have any idea what might be wrong? Can you guys/girls give me some suggestions, opinions, experiences?
-ThankS
