float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Jan 15, 2007 9:59 am
For some reason the CA is just kinda cold blooded. Your recirculated BOV shouldn't cause any problems.
Things to check for are leaks in the system, an adjustable FPR if you're using the walbro, a SAFC if you're using the KA-E MAFS (some people have problems others don't), coolant temperature sensor (the 2 wire for the ECU, not the single wire for the gauge cluster), correct ignition timing, and make sure all of the idle control valves are working properly and recieving signals from the ECU like they should be.
