NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Aug 12, 2005 5:14 pm
Niether o2 will stop the car from starting and running.The front O2 is the only one used on any car to Asist in maintaining proper fuel mixture but it is not enough to stop a car from running altogether. Just because your not getting odd poping does not mean the firing order is correct or the timing is out of wack. For combustion to take place you need compression. If the firing order is set up in such a way it is firing on the exhuast stroke you have no compression to ignite the fuel. If your smelling gas on the plugs it sounds like your flooded. If you had a weak spark you may not get combustion either. Charge the battery up for a good 6 to 8 hre then try to start it holding your foot to the floor. when it starts to come to life start backing off the throttle. Clean the plugs best you can while the battery is charging.
