ChavezSA »
https://forums.nicoclub.com/chavezsa-u7088.html
Fri Feb 11, 2005 11:56 am
I'm having a very similar problem. Except, mine isn't just during cold weather.
The other day I got stranded at Taco Bell. It took me about 25 minutes to finally get it running. I had to manually throttle from the throttle body, with my friend cranking on the ignition to get it to start. I went to Autozone and I got some Gumout, and I bought a couple of quarts of oil, since I noticed it was awfully low. I haven't gotten to try the Gumout, because since it requires mixing it with a full tank of gas, I was afraid of getting stranded at the gas station when I'd have to the car off in order to fill up.
Since it was a nice day outside, I tried starting it again today. It didn't want to start. After about 20 minutes of messing around with it, I found that the #1 spark plug wire was loose. I made sure it was snug and tried again. No luck. So, I waited for about 5 minutes. Cranked it and started right up. Cool, I thought. I let it idle for about 10 minutes. Turned it off, just to see if it would start right up again. It did. Wow awesome, I kept thinking.
I went inside to grab my paycheck so I could head off to the bank. I came back out and the car was still running so I thought that was a good sign. But, I wanted to be 100% sure I wasn't going to get stranded. So, I turned it off and tried to start it again. Good thing I tested my theory. Now it won't start again.
I spent another 40 minutes cranking on it, letting it sit, and trying to figure out WTF is wrong with it. Finally, I got someone in the neighborhood ot give me a hand. While he was cranking on the ignition and I was manually throttling at the throttle body, the starter went.
Well, either that was the problem all along, or now my problem just got worse.
