Daledude wrote:I am about to go crazy. I posted this before but I have some new info and wanted to get opinions. I have a 2003 G35 sedan and my car problem is this. .... Sometimes the car starts on the first try. Most of the time you have to crank it 2 or 3 times to get it to start. When it does start slowly like this it sputters a little then fires up. It starts better in cold weather than warm weather and it usually starts right up first thing in the morning but is harder later in the day. The dealership tried replacing my batter, cleaning the TB and injectors, and replacing my MAF. No difference. Now they tell me I have low fuel pressure at startup and at idle. In reading my manual I see there is a fuel pump, fuel pressure regulator in the tank, and a fuel damper at the firewall. Would you replace any or all of these to fix low fuel pressure at startup and idle? Thanks.
Daledude
I feel your pain
My first car was a 1958 $uckin Ford 352 cu in that had the same problem. After replacing coil, ignition wires, distributor cap,points,plugs, condensor, fuel filter, fuel pump, the $uckin car still wouldn't start when it rained so I got rid of it. Perhaps your G is made from recycled parts of my old Ford?
My advice is to take care of the service people at the dealer $$$. Take a loaner and tell them to call you when they find the problem. You shouldn't have to pay for every part of your car while they try to find the problem. Ask them to return the old parts to you of every part they replace.
Telcoman
