So you turned up the boost but you didnt mention changing the ECU map and adding fuel. If the manifold is glowing its running too hot.....if changing the timing isnt getting it done....add fuel to the map.BQ.05.TD wrote:so i got me car tuned the other week and it made 190.1kw on 13psi. i was pretty happy with that power. so then we started screwing the boost into it and on 19psi it made 198kw. so i only got 8kw for 6psi extra boost pressure. wtf
i have a gt2876r .64
my tuner thinks its the rear housing causing the restriction. but i have seen plenty of .64 housings make more then 230kw which is my goal figure.
i have checked my cat and its fine and so is the rest of the exhaust.
i spoke to a bloke at GCG and he had a ca with 2871r and made 233kw on 20 psi. so where am i going wrong
i know the 76r isnt the best turbo but surely it would be able to make the 230kw im after
my 3mm thick steam pipe manifold that is HPC coated was glowing red hot at the collector and my tuner only sees that on big boost cars
the motor has great compression and every thing in spot on
he spent a full day on the car,playing with the adjustable cam gears ( stock cams atm)
if any one has any ideas i would love to here them
i dont mean to be rude man but do u realy think that he just added boost and ramped it up?mbmbmb23 wrote:
He didnt mention modding the map...so I have no idea. Ive seen worse on this board. I was under the impression he bumped up the boost with no fuel/timing MAP mods and it was running lean and thus glowing when it shouldnt have. End of story.BQ.05.TD wrote:i dont mean to be rude man but do u realy think that he just added boost and ramped it up?
yer i know jsut because the manifold is glowing red dosent mean its lean. they all do that after a work out but 3mm thick and ceramick coated it shouldent be glowing on 19psi like it did
that is the manifold
