WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun Feb 09, 2003 8:38 pm
Personally, if i was in the states I would use REDLINE for everything. But over here I prefer Mobil 1, 15W50 which I use in my motor aswell as my transmission. I use slick 50 gear lube for the rear end and whatever is onsale for the rest.
You might not want to go to a heavier transmission fluid though. I use my car for alot of drag and the transmission gets abused. So I switched to a heavier fluid as a suggestion from some fellow racers. No problems after a year of use. But I believe the thinner fluids will shift smoother.
All of the above is also on a Skyline, not a 240.
WD
