Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri May 20, 2011 3:02 am
Well, if you wanna replace the Det sensor, that requires an upper and lower plenum pull, and it''ll still be next to impossible.
The coolant temp sensor plug is on the main engine harness, and can only be replaced by splicing a new connector on. You'd have to find a connector to splice on, as I don't think they sell them separately.
And just FWIW, the knock sensor isn't gonna be causing any of those problems. The coolant temp sensor, however, could be a major hiccup.
