MadSideways »
https://forums.nicoclub.com/madsideways-u3356.html
Tue Mar 02, 2004 10:24 pm
The stock intake manifold is very restrictive. You'll notice most dyno charts with the stock manifold tend to stop producing power at about 6300rpm...
Also, factory cams are designed to produce the most power at cruising speed, which would be between 3000 and 5000rpm...
Upgrading to the greddy plenum makes a huge difference in power above 5000rpm....but with added cams and a couple dyno runs to tune the ecu, you can almost rev to infinity, although you may blow your motor, there'll be no loss in the powerband...
Ofcourse, all of this is assuming you have full 3", unrestricted, intake and exhaust, and your turbo isn't passed its efficiency range.
