you guess so? are you trying to fix the problem or make it worse?! .24 thats HUGE.black240jl wrote:yeah i guess so, i have brand new ngk R plugs in there now jsut gonna gap em and see if it fixes the problem...i hope so
Sounds like you need to reset/check your base timing.rb25drag wrote:I ran those 11's and had no luck Carl! Mine kept detonating @ 10lbs of boost @ 4000rpm's , I switched to the much colder Acdelco 6's and problem solved??
I notice mine doesn't like 93 octain either. Seems sluggish, I put the 112 race gas in and its smooth as ice!! But thats up to 8$ a gallon so Rb's been setting for a while!
I have, its set at 15 degree's, I backed it off to 5 defree's trying to get it not to detonate but it didn't help, Plus at 5 degree's it wouldn't Idle without loading up with fuel.Shocker wrote:
FPR at 43psi with vac, and holds after full boost is reached?rb25drag wrote:yup & yup
got a pump you want to go to a good cause?? lol (but seriously??)rb25drag wrote: Im trashing all the fuel equipment, When i go to propane none of that stuff is going to be needed, And tuning is going to be easy!
so what would happen if someone happened to set their gap to .08 INCHES?? what would the car do if there is too much gap? any affect on fuel pressure? lol (feeling kinda stupid right now...)Shocker wrote:
.8mm works out to be .031", gap to that and go from there.
cut the crap and get the NGK 3330 (BCPR7ES) it helps prevents detonation a little bit on bad gas mixture. i don't care what others saying about it.rb25drag wrote:I ran those 11's and had no luck Carl! Mine kept detonating @ 10lbs of boost @ 4000rpm's , I switched to the much colder Acdelco 6's and problem solved??
there's no what if, gap that thing correctly or go home.black240jl wrote:i have brand new ngkR plugs, put em in about 3 days ago thats when it started doing it, i will gap em to about .28 and see how it is, should i get better plugs or?
so, it runs better with the plugs gapped better, gotcha on that. but wondering, did your car run lean when it hit that wot point? did you ever test it?black240jl wrote:it was the plugs, thanks
I am running the bcpr6es but I never understood what the "-11" meant. But I am gonna regap them to the correct setting of .031 inches and I am waiting on my vac/boost gauge and another new walbro pump, this time to replace my bosch 040 (a downgrade) that is probably gone out. Builds pressure, but fuel flow is weeeeaaaaakkkk...shally2186 wrote:i have a RB20 with little mods running on the bcpr6es-11's..runs great!! i had detonation problems in past but it just ended up being my fuel pressure..im on 40psi @ idle and the car is runnin better than ever
