frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Thu Jan 30, 2014 8:17 am
Good job patching the exhaust leaks. Do you live in a part of the country that treats their roads with salt? That might have been what led to the cracking. The stock manifold is cast, and the only way you'll see an issue with it is if its cracked. If it isn't cracked, I'd leave it alone.
As for your suspension, its really up to you and your financial situation. Replacing shocks will also have the added cost of an alignment. If you go with coil overs, you'll potentially sacrifice the quality of the ride. Really, its up to personal preference. If you are into performance, spend the coin on the upgrade. If not, just enjoy the stock replacements like you have.
