navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Tue Feb 22, 2005 4:03 pm
use a mechanics stethiscope to listen to the front of the engine, try to pin-point were the sound is coming from, if its coming from the front, that may be your timing chain, which is a fairly common problem on the 240's. it could also be your injectors, as they can sometimes be quite noisy.
