nomadikone »
https://forums.nicoclub.com/nomadikone-u30077.html
Mon Jun 27, 2005 2:29 pm
Hello, I have a lingering problem with my car. About 1-2 years ago I replaced the stock air intake on my 92 240sx with an after market cold air intake kit. About 5 months ago, my car started shaking as I drove on the freeway and then eventually turned off. I was told that the problem was the mass air flow meter. I changed the part and the car worked fine for about 3 months. Then the same thing happened again (car started to shake, it sounded like it was gasping for air, like a vacuum and then turned off again). I took to another mechanic and he changed the distributor cap and rotor, changed the oil/filter, did a tune-up and cleaned the fuel injectors. I also changed the fuel filter. The car worked fine for about 2 months and now...once again same problem. I can turn on the car, however, the engine rattles and then turns off. I am becoming frustrated with the so-called "mechanics" as I feel as if I know more about my car than they do most of the time. However, this time I would appreciate anyone's help. If you can help me with a post or if you are a mechanic in the South Bay area in Cailfornia willing to check out/work on my car let me know. I am looking for someone who really knows 92 240sx's very well. Please help... ...
