An Impact Wrench powered by the 12v? While the car isnt running no less?I dont know anything about it really, but the knowing what an impact wrench does, i dont think itd be a good idea to try this.... what if it pops fuse etc before you are finished?GryStrm wrote:gosh buddy i cant see that thing working of a car battery....i used a compressor fired impact gun and it banged away a few before loosening it...i have a feeling ull blow the fuse for the lighter b4 that thing comes loose....but then again...i never tried it
dude, I tried using a manual wrench on it with all my weight on it and it just did budge at all!08altima35 wrote:i personally haven't had great luck with stuff that plugs into cig lighters, nor has anyone else i've known. a cell phone charger, ipod charger, charger, charger, etc. will do just fine.so far as power tools or compressors? they work to some degree, but not worth a damn and prolly not well enough to undo 98lb. torqued bolts.
what's so bad about using a manual wrench and socket anyway?
must we take your "man card" away mehdi?
GryStrm wrote:breaker bar....use a heavy duty socket...a hollow pipe at end....and lean....wait...question is why are they so stuck>?unless..... lol!...too much mouse clickin on photoshop cupcake?....ha!seriously and no pun intended....stuck nuts aint a good thing....either over tourqd' or possible strip thread..id hit the bolts with wd40...let em soak abit then...hit manually... an impact gun may cause a bigger problem if there is one to begin with!
HA!GryStrm wrote:wait....that 15$ thing worked?....shoooot....and im using a 2500$ tank and gun setup with a lift in my garage????
or ask us and send 10$ + shipping and handling we could mail it down to you for prolly 15$ at the end of the day...LOL....but that 510$ sounds mighty tempting.....GryStrm wrote:ok so it says only avialible in stores...so ill just have to come up to canada i guess....lets see..gas at 4.15 a gal..tire wear and tear...food..drink..hmm,,,about 500$... i like to eat and drink!10$ for the thing..
so i can have a car powered impact wrench for 510$....
done~!
