Ultimate car paint fixing regiment
1)small orbital buffer, extra pads $15-$20 at walmart1)Tub Turtle wax rubbing compound $21)Tub Turtle wax polishing compound $21)Tub Meguiars cleaner wax.
It will take a good solid day. Dont let either of the compounds dry. Use lots of water with both compounds. Take your time and let the buffer do the work. Remember to work in the shade. Paint should be cool to the touch. Also, take your time with the rubbing compound. A few minutes per square foot will do. The more compound you use, the faster it'll work. Try to space it out so the tub lasts the whole car so you don't have to buy more
If you are lazy, you can skip the polishing compound, but i suggest it
You'll be amazed with the results
