Car dying at 3500 in 5th gear
mikemcgrath4
Car: 1990 nissan 240sx
Ok i have a 1990 240sx ka24e. This is my problem, when im on the interstate if i accelerate up to about 3500rpm in 5th gear, my car will die out until it gets back down to about 3000rpm again. When it happens if i push the gas pedal in i does nothin until the rpms go down again. Im not sure how fast i am goin because my speedometer hasnt worked for the past year( ) but im pretty sure that im not going any faster than 80mph. Any ideas what it could be. Its getting pretty annoying because i cant pass people when i need to. thanks for any help
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
I've have the exact same problem from time to time, also in 5th. It only does it every once in a while, so it hasn't really bothered me, but I'd like to know what the hell this is as well.
mikemcgrath4
yea it happens to my car almost everyday, although every once in a while it doesn't do it
fetherw8
Car: 1989 240sx
i think that is what happens when your computer recognizes something wrong. mine did it cuz my CTS wasn't working. when i figured that out and replaced it it went away. coincidence? maybe, the cut out was pretty intermittent.
go through all the sensors in the car and make sure they're all working, something may be not working correctly even if the check engine light isnt on.
the older sohc computer is usually the one that tends to cut out the most (the one with the number 10 on it). i switched out my computer to the newer sohc computer(number 14) and it didnt do it, put the older one back in and it did it.
but yeah thats what i think it is. i asked the same question like 6 months ago and nobody could help me. so i had to figure it out myself. thats what i did to fix it.
good luck
mikemcgrath4
Thanks for the help man. I will probbaly get an ECU from a junkyard, but what is the CTS, collant temp sensor right? Thats on the intake manifold right?
nj240
hey i have the same probem it does it at 4th gear and 5th gears then sometimes it goes away can it be the the sensors conected to the transmission ... ?
fetherw8
Car: 1989 240sx
it could also be that although a few of the plugs on my transmission arent plugged in and it hasnt been an issue for me.
dont jump to conclusions with it being the coolant temp sensor or the ECU. test all the sensors and make sure its one of them. no need in waisting your money on a ECU or a CTS sensor when it could be something else
mikemcgrath4
well i know its not my speed sensor because i replaced that when trying to get my speedometer to work(still didnt work) And im wondering if the speedometer problem and dying thing could be related, does the speed sensor go to the ecu before the cluster?
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
mikemcgrath4 wrote:Thanks for the help man. I will probbaly get an ECU from a junkyard, but what is the CTS, collant temp sensor right? Thats on the intake manifold right?
I have an SOHC ECU I'll sell.Hit me up at [email protected] with a price, and ill get back to you today!
Thanks!Tony
mikemcgrath4
I put in a new ECU, im still getting the same problem, and more ideas?
urcaptnspeaking
Car: 2007 Ford Fusion
2001 Honda Accord
1978 Pontiac Trans Am
yeah its your limiter theres a wire you can cut I guess or just get the ECU's limiter removed. Mine did it as well.
mikemcgrath4
It really shouldnt be the limiter though cause im not going fast enough
urcaptnspeaking
2001 Honda Accord
does your speedometer work? If SO Im not sure if the speed sensor could still do that, but you could try it
PHeller
Car: 1998 Ford ZX2 (wrecked) now 1989 Coupe
dead thread.
Sounds like other people are having a similar issue as me.
Speedo dies. Car cuts out.
StonedRhyder
Car: 91 240sx ka24de
I'm getting the same thing with a working speed. I also have de engine.
Johara2320
Car: S13 Hatch - Sold
S14 Zenki - Current
Pull a code from the computer. I had a similar problem with ignition cutting out around 2500-3k no matter what gear I was in. I pulled a code and it said "cam position sensor". Bought a used distributor from a junkyard and the problem was solved.
StonedRhyder
well i would do that but this would be my 4th or 5th dizzy, something has to be killing the sensor. Does anyone know or have an idea what it might be?
