rn79870 wrote:GrandAm350Z congrats and best of luck with the season.
You corrected some of the values stated for weight and HP, but not the torque. Does the engine put out 400 lb/ft of torque, (if so) what did you do to get that?
We're closer to 300 ft lbs, but it's a pretty flat curve. The ECU we're using, the Bosch MS 4.3 wasn't talking to the cam controlers at the right frequency, so we've got to go back and fix that. Once we do, we should see some more power out of the motor. We're running a stock motor with Nismo cams and header. That's it.
-Rich
