Car doesn't pass 2300 RPMs on any gear
silvia tunner
Car: 1995 Ruby Pearl s14
I've changed the oil, spark plugs, fuel filter, but the problem doesn't seem to go away. when the car reaches 2300 rpms the car starts bogging like if it had no gas. my friends think it might be the fuel pump or the MAF sensor. does any one know what it could be.
http://members.cardomain.com/projectmaroons14
easymmkay240sx
check your ECU, more than likely it's the MAF
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Sounds like the car is running in "safemode".. When there is something wrong it wont go past 2100 or 2300k
Check the maf like easymmmkay said
Hijacker
Car: '92 240sx Convertible
'94 F-150
check your ECU to see if it's throwing any codes. More than likely it's a maf, but to be on the safeside, i'd check the ECU
ELITEBB127108
MAF....
nissandrift
Car: BMX, motorcycles, classic mopars, and nissans
That's the symptoms from my auto when the MAF went out, but then again I replaced the MAF when my 5sp gave me the code 12 and it didnt do any good. The ECU was the prob the second time. Now I have 2 extra working MAF's. Email me at [email protected] if you need one of em. Name your price.
nissandrift
Just realized you have an s14, my MAFS won't work. But still check ECU and MAFS. Check the wires on the harness, there should be a ground, a wire with somewhere near 14 volts, and the wire going to the ECU. I think it should be around 1.2 volts at idle.
silvia tunner
the fuel pump wouldn't be causing these symptoms?
ricebike
2002 Quest
2005 Altima
nope... like everyone else on this board... check MAF/ electrical plug to it... the ECU should also set a trouble code if you unplugged your MAF lately...
silvia tunner
how much would it be for a MAFS
GEO
Car: 95 240sx KA-T
yeh reason the wattage is messed up and jsutreset your ECU if you have a stock ECU..
silvia tunner
i've reset the ecu by disconnecting the battery for 15 min and then i connected it but acouple hours later the problem started again.
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
then it might be your ECU.... If when you reset the ECU it didn't have the problem, and then the problem came back a few hours later... Just my thoughts....
easymmkay240sx
Check all the connectors/wires for the MAF. Something may be corroded or you have a dirty/loose connection.
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
try disconnecting it overnight..
silvia tunner
2 days a i read that u could try to clean the MAFS sensor with rubbing alcohol, so i tried it and it worked hasn't given me any more trouble.
