car doesn't lean out when i let off
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
yeah after i've changed my tps and i have it set to .45 v at idle and now the car doesnt' seem to want to lean out when i let off the throttle. this leads to me stalling at every stop sign even when i try to blip it alittle.
anyone else experience this? this is too weird for me, what else would cause the car to not lean out?
setup
running 15:1 afr at idleidle rpm is 800-850 i have my type S recirculated
Structure240sx
are you still in gear or is it when you put it into nuetral?
S14tat
Car: 2007 FX35
1994 Acura NSX
when i'm in gear
Structure240sx
this happen to me before when i first blocked off my IACV on my stock intake manifold and cracked open the throttle body
then it started to lean back out jsut like it used to.
why do you think this causes you to stall?
Nismo_Freak
Car: 89 Nissan 240SX
Raise your idle... my SR idled around 1000 - 1200 RPM and it never stalled hehe.
S14tat
Car: 2007 FX35
1994 Acura NSX
cause it stalls from being too rich when i let off. for some odd reason when i let off, it doesn't go to lean and it just chills at 14-13:1 afr. yeah i was think about it all night, i might have to either raise the **** out of the idle or crack open the throttle as a bandaid.
