amiry36 »
https://forums.nicoclub.com/amiry36-u205953.html
Fri Jun 27, 2014 7:29 pm
Usually a boost leak results in a rough idle. As you mentioned, it idles fine when you tap the gas pedal. As suggested, check your throttle position sensor for proper adjustment. as if it is of, it can cause the ecu to make a wrong judgments. Other thing that i would suggest is to check for the iacv proper operation. You can do this simply by pinching the rubber hose that goes to the iacv unit from front to back on the driver side of engine bay. If you pinch the hose and the idle doesnt change, it means that the valve is not operating correctly, hence causing that problem you have. Also another question i have is that is the idle adjustment screw all the way out? Can you raise the idle anymore?
