car dies when oil cap took off
capwred
ok i got ka24de. When the cars running and i take the oil cap off it dies. So if anyone can help with this it would be great.
I just got the car 2 days ago and it drives fine. has new plugs,wires,cap.
Madmax3
Car: 1990 nissan 240 sx
Why would you take the oil cap off while the engine is running?
S13FASTBACKSR
Car: '92 Fastback SR powered
just dont take the oil cap off and your engine wont shut off..simple as that..theres no reason why you should take the cap off when the engine is running anyways
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
capwred wrote:ok i got ka24de. When the cars running and i take the oil cap off it dies. So if anyone can help with this it would be great.
yea what the heck? what is your purpose for taking off the oil cap while the car is running?
and it's, "I have a ka24de."
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
your car runs a closed crankcase ventilation system, when you take the oil Off you are in effect creating a huge vacuum that's why it quits it's also normal
guyaverage
Car: Nissan 240SX Convertible
When you take the oil cap off, you arent creating a vacuum, you are destroying one. (You wouldnt create a vacuum in the crankcase by opening up a gaping 2 inch hole in the valve cover!) Anyway the crankcase is at a very slight relative VACUUM compared to ambient, when you take off the oil cap you are increasing pressure in the crank to equal ambient pressure, allowing unmetered air into the intake via the pvc valve, which causes an over-lean condition which is the cause of the stall.
Q. "Doc, my arm hurts when I go like this. What should I do?"
A. "Dont go like that."
= solves the problem. Leave the oil cap on. No reason to run the engine without it other than to watch the camshaft spin.
