Car Dies When Jumper Cables are Removed from Battery
gtd65
Car: 1995 240SX SE
Hi Folks,
Our car has been standing for a while due to a cracked gas tank. :frown:
The battery was flat, so I decided to jump the car and after a couple of cranks it fired up fine but I noticed a couple of things that were unusual:
1. The headlights were on but the switch was on the off position (before cranking)
2. The clock display was illuminated but the time was not showing.
3. When I removed the jumper cables the engine died.
I'm assuming that this has something to do with the alternator but points 1 and 2 have me somewhat confused?
Any ideas?
Cheers in advance :dblthumb:
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Id start with the alternator and diagnose the other issues after it can stand on its own 2 feet.
gtd65
Car: 1995 240SX SE
I've been reading posts about 75A fuses - does this apply to the S14?
180sx91
Sounds like the altenator
compactfean
daily
gtd65 wrote:I've been reading posts about 75A fuses - does this apply to the S14?
Yes, the wiring for the alternator goes alternator, fuse, battery.
gtd65
Car: 1995 240SX SE
Got the alternator checked at Advance Auto Parts and all is well with it...
Interior electrical problem remains....
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
Check Your grounds for rips or tears, metal to metal contact can cause those problems
Alternator fuse.
If your alternator is good, you're not getting power from the alternator to the ECU.
gtd65
Car: 1995 240SX SE
AZhitman wrote:Alternator fuse.
Would the alternator fuse (is this the 75A fuse?) cause the interior electrics not to function?
e.g. power windows, dome light, dash cluster lights etc.?
Thing is I got a spare 75A fuse at the wreckers yard and it made no difference - has to be something common that's being overlooked here..?
gtd65
Car: 1995 240SX SE
jbracy7 wrote:Check Your grounds for rips or tears, metal to metal contact can cause those problems
Everything looks good with the grounds and I cleaned up the connectors for the alternator and the ground near the strut top/battery area. No change.
Also now got gas tank changed for a good one, one problem solved - electrics to follow hopefully!
compactfean
daily
Power windows, dome light, etc, is on another fuse, and could be a separate issue. Have you checked continuity from the alternator plug to the battery? or from the alternator plug to the 75amp alternator fuse? checked resistance in the alternator fuse itself? If all is good than alternator or ground is your issue (ground is pretty obvious, battery - straight to chassis)
gtd65
Car: 1995 240SX SE
I'll get a check done on the grounding (I'm out of state right now) but as the car cranks over and starts fine I'm assuming that the battery ground has to be OK?
All of these problems appeared at once, after I disconnected the wiring to the gas tank...or at least there wasn't any problem with the car until I decided to do that....
Is the dome light fuse/circuit in any way connected to the grounding of the alternator?
gtd65
Car: 1995 240SX SE
Just been surfing around and found this snippet:
If:
None of your gauges, accessories and dash lights work then its the alt fuse.
or
If none your dash lights and rear lights work then its the rear lights fuse.
Rays240sx
Car: 1995 Nissan 240sx and G35 coupe
i had a similar issue, it ended up being my 75A fuse
gtd65
Car: 1995 240SX SE
Rays240sx wrote:i had a similar issue, it ended up being my 75A fuse
So your car wasn't the SE version?
Ive read now that in the SE you need to check the 100A fuse?
I'm really hoping it's that simple!
Mercury_Hg
Car: 1993 240SX Coupe
gtd65 wrote:Ive read now that in the SE you need to check the 100A fuse?
Yup.
gtd65
Car: 1995 240SX SE
YUP - 100A fuse is blown - need a replacement!
