W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Mon Jun 09, 2008 6:18 pm
Been having this problem for a while, finally pissed me off enough that I might aswell fix it.
I rolled my 01 qx4 a couple months back and I think its been happening since around that time. If the car is COLD and you start it, it fires up and starts just fine, jumps to 1000rpm, then just dies, no puttering, just drops.
Give it the SLIGHTEST gas and it run just fine, dont even have to hold the gas, just that one second touch on startup and the car runs mint.
THEN
Theres I THINK a low idle, seems to be down in teh 500rpm area, which seems low with my lights on and such. Turn the light and electrical accesories off and it goes to 650ish and runs minty. If the cars been run for a while you can tell at a stoplight, it purrs and is smooth @ 600+ stays there for a second, down to 500 and the car shakes a bit, does that for a second then back up to 600 (maybe not that much fluxuation but obviously enough for the motor to run smoother)
You can physically see the motor shake when the rpms drop a tad.
Was curious if these 2 problems are a quick fix and if they are related, was hoping there was an idle adjustment screw but couldnt find one.... would solve all my problems.
Im also no throwing any codes, havent since I bought the car, which I think is weird, maybe they took the bulb out? Anyway to tell quickly if Im throwing any codes?
Love to hear your guys input on this.
thanks
