car died upon shifting into gear
jives
Car: 92 240 SX
recently removed thermostat in 92' 240 SX to check on the cause of overheating problem. while on test drive car ran fine temp held etc. stopped at store for two minutes to grab a soda. came out got back into car put it into reverse and pluhhh dead car will not start
2ndnissan
Car: 1990 240sx hatch
have you checked the obvious things like battery connections and the alt fuse? I had a weird no start once that involved a plastic plug that helped actuate a switch on the clutch pedal. Switch did not work because the plunger would not go back in.
jives
Car: 92 240 SX
i will check the connections and fuses in a short while, thank you for the suggestions im running back and forth between the pc and the phone trying to get the pos home all and any tips and clues are welcome at this point
hilux30
Car: 2007 Tacoma 4x4
you need to be more specific: died as in no battery power? died as in crank but no fire? or has battery juice but no crank????
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
had the same thing happen to me on a different nissan, i replaced the throttle body and everything worked great again. it literally was the same scenerio and it pissed me off cuz nothing was obviously wrong.
