MAXIMUS Nismo »
https://forums.nicoclub.com/maximus-nismo-u648.html
Tue Jan 04, 2011 7:55 pm
About 2 weeks ago I had to change the negative battery cable. The one I got only has the single ground point on the engine while the stock on has an additional ground on the battery tray itself. A few days later, the battery icon showed up on the dash and hasn't gone away. This morning I went out and the car would not start. The battery is a Duralast Gold that is 3 years and 4 months old.
I jumped started it with another car and by the time I parked the other car, the 240 had died.
Took battery out and took it to Advanced Auto where they tested it. It came back with 115 CCA instead of the 640it should have. IT was charged for 30 minutes then tested again and this time ti read 629CCA. Took it home, put it in and it started right up.
Went for a drive with the Battery light still lit, got about 2 miles from home and was sitting at a light. Light turned green, I moved off and the car started to die. It was bucking and loosing power like it was running out of gas but with the added bonus of the electrical system going out. i.e. radio, lights, horn, etc...all fading fast. Right before the death rattle started, the airbag light started flashing and the brake light came on.
I walked to Autozone, borrowed some tools and bought a replacement, went back to Arby's where the car was and put it in. Drove to Autozone to return tools and old battery then drove home. The battery light and brake light were still lit from I put the new battery in till I got home. (about 3 miles.)
What do you think the issue could be?
