nickchaffey »
https://forums.nicoclub.com/nickchaffey-u103483.html
Thu Aug 14, 2008 8:39 am
Hi yes it seems to be fine after first starting up! it plays up once it is up to normal operateing temp. A friend told me to check the voltage at the temp sensor 5volts when first started then should drop 1ish? have just done this cold with ignition on 3.5v as it heated up dropped to 1.1/1.2 ! wiggled the suspect scotch lock conectors from the HKS AFR (set to 6) to the ECU while running all seemed ok no cutting out etc. Seems to be better than yesterday revs will pick up ok when hot now but if i raise the revs to about 2,000 the revs still drop down to about 200/300 then jump to about 1,000 then drop back to about 750 ????? I havent driven it up the road yet to put it under load but out on the drive it seems to have improved over night. I wonder if some water did get in somewhere and is now drying out????
