bigE »
https://forums.nicoclub.com/bige-u7035.html
Sun Oct 26, 2003 5:45 pm
Well maybe someone here can figure this out, been almost 4 months since the problem started, and we and everyone else have not been able to figure it out, I've stumped a lot of people. here it is,
Car died one day after I had washed it, took about 10 cranks to get it running, but it wouldn't stay running, starting off in 1rst gear, it seemed as if the governor was kicking in, at 2000 rpm. Well I drove around later, and the car kept dieing at lights, and while I was driving it, it kept cutting out almost like it does when you hit 120, and the gov kicks in then when the rpms dropped a tad, it'd kick back in hard until it got back up to the rpm where it had cut out at. It would do it in any gear generally between 3 and 5k rpm. So I figure a sensor or something under the hood is loose or acting up, so I yank out the MAF and clean it and it still happens, so I go to the gas station and fill my car with gas since it was getting low. Well the problem was gone, or so I thought. It was gone for about 200 miles on a 400 mile tank of gas, it would start back up for about 20 miles, then smooth out finally and it would happen about every 75 miles after half a tank or 200 miles.
Over the past couple of months, we've replace the plugs wires, dist cap, rotor button, fuel filter, fuel pump to a WALBRO 255, fuel cleaner, and the problems still there. Except now it starts after about 75 miles on a full tank of gas, but whenever I fill the tank back up, it's gone for at least 75 miles. So it seems like something correlated with how much gas is in the tank.
Cars pretty mcuh unsafe to drive now cause it seems like whenever I need to get on it, it acts up and cuts out. Lately its been so bad that it cuts out every time I stop at a light. I can't fill up my tank every 75 miles to keep this from happening.
Anyone have any ideas?
Eric
