CAR CRANKS BUT WONT START
Omni
ok guys well i finally got the car cranking but it wont star and i know you guys might say i gotta search the forum blah blah blah...but i would like u guys to address me directly...well i am getting fuel i am pretty sure im getting spark but still nothing....i know i got everything on the harness right but still for some reason nothing and im getting stressed with the car i would like to see my hard earned money go into action and the car starts HELP SOMEONE PLEASE
SlowKoop
Car: 350z s13 coupe
I had a bad wire for my water temp sensor not saying that's your problem but my car wouldn't start unless I tried starting it for like 10 minutes straight. Worth a look the fsm shows you how to check voltage and ground for sensor plug.
platez808
Car: 1989 Nissan 240SX
what engine is this for?
i would say to:
make sure that all the grounds are on tight.
see if the light on the ecu turns on when the key is put into on position
make sure fuel pump primes when the key is put into on position
make sure the fuel lines arent reversed
pull the fuel pump fuse and crank it for a minute or so in case the engine flooded with fuel
with the key in on position turn the CAS and listen for injector clicks to make sure its functioning
set the CAS so that the screws are in the middle of the slots
try starting the car with the maf unplugged to make sure the wiring isnt the issue
i say all these things from experience but i wont take any fault if something goes wrong.. haha just gotta put that out there.. dont necessarily have to do it in the order i wrote.. good luck
Omni
well on my ecu i see no light i actually see where the light is suppose to be but the plastic is still over it..so i dunno what to do in that area...i am hearing my fuel pump priming...i took out my spark plugs and they were wet with fuel so the injectors are pulsing...i also hear the cas spin when i put the cas wire in plug my battery in...uhm the only thing i see that could cause anything is the spark plugs which were looking like they were super fried and the light on the ecu which i do not have..and this is for a rb25 s2
Krazykouki
Omni, enable your PM's
Omni
ok sir
StricNyne
did u check for spark, and if plugs look burnt, then replace with bkr7e from advance auto
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
If it had fuel and spark, you'd have a car that started. Verify that you have spark by disconnecting the fuel injector harness, pulling the plugs, reinserting them into the coil packs and resting the plug tips against the valve covers to ground them. Then, have someone crank the motor while you watch for spark on all of the plugs.
Omni
WELL GREAT NEWS GUYS
i got it started np and now when i turn off the key the s*** still running hahaha smh thats some s***...and also my dash lights come on as i plug in battery without key even being on help anyone
Krazykouki
Omni wrote:WELL GREAT NEWS GUYS
sounds like you have an ignition wire cross up somewhere...likely the eccs relay wiring.
I've been trying to PM you but your PM's are still disabled.
Omni
i enabled them sir..i dunno why the hell they are not working and i did get my driveshaft if thats what u are trying to pm me about
Omni
and i will also check the eccs relay and see whats going on
