car cranks but wont start! hellp 89 coupe
s13lovesg35
Car: 240sx coupe 93
so i turn the key . .when i get to last position that the key can sit at before turning the engine on i hear this weird clicking and a lil clunking . .then i turn it on and it cranks but doesnt start. . .! i serched and nothing:/ . . its a ka24e
Rucca
I searched "crank no start" and got 6 results. You try: zerosearch
None of them seem like they really apply to you. But, strangely enough, I bet if you search more, or give this problem a little extra effort, like checking for codes, you might find something useful. Good luck
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
what have u tested give more examples of your testing and your results and it would be easier to diagnose
smokerider
Car: 90 nissan 240sx
check to see if it is getting spark,. if it is then check to see if it is getting gas to the cylinder.i just swap a new motor and cross the fuel return line,. once i got the fuel going to the cylinder it started right up. i have a good spare on everypart of the car so when something goes wrong i just test the parts instead of buying something you dont need. took me three motor swaps and junkyards to collect but all worth it.good luck.holla back
crank no start search only give u and idea but not help. been there done that.
