Car cover recommendations
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
salvo620
Car: 2011 Infiniti G37x
Hi,
Just reaching out to see if there are any specific car cover recommendations.
I have a 2011 G37x and recently had an issue with a clogged sunroof drain that has recently been fixed. Figured I’d invest in a car cover, since I park under a tree that is likely the culprit of the clogged drains
Anyone here have any reasonably priced waterproof car cover recommendations?
Thanks in advance!
PalmerWMD
Car: 2004 350Z
I bought a very car cover from Nissan for my 350Z back in the day, factory made for that car.
I would not be surprised if your Infiniti dealer does not also offer something similar.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The G sunroof drains have the same old problem as practically all Nissan products since the early 00's. Knock out the diffuser nubs in the drain fittings and you'll probably never need to snake another drain:
post6844183.html#p6844183
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
VStar650CL wrote:
Thu Feb 12, 2026 9:23 am
Just a heads up, I think kirax0 is a spammer.
VStar650CL
Technical Expert
Well, other readers may still want to know that they don't need to put up with clogged drains and weed whacker cord once a year. No harm done.
Return to “G35 and G37 Interior, Exterior and Audio”
