Q451990owner »
https://forums.nicoclub.com/q451990owner-u223771.html
Fri Oct 25, 2013 6:09 pm
I have changed the MAF sensor, replaced 3 bad injectors (1,2,8) replaced spark plugs, new fuel filter new fuel pump new gas tank , new air filter , cleaned throttle body.
The car will intermittently be missing on one cylinder, check engine turns on and it will go away after a minute and stop missing and check engine loght goes away.
On the freeway, if I kick down, it lowers a gear, and the RPM gets choked and it feels like the car wants to s*** down, when I let go the gas pedal the RPM returns normal and car is fine. What could it be,
