ok, i got it into the shop today and they figured it out...try to bear with me... The ECU's signal that's sent to the Mass Air Flow Sensor isn't getting there sometimes. So the modified 12 volt signal isn't getting sent back to the ECU so for some reason the computer thinks it's hitting the rev limiter causing a momentary cut of fuel and ignition. Then suddenly the signal reaches the MAF and all is well for another 1/2 second then the cycle repeats. They have to track the problem down to somewhere in the communication lines between the computer and the MAF, it may even be the ECU itself, they mentioned. They're keeping it overnight so we'll know in the morning...
Also i found out that there's a leak in the Intake manifold to Head gasket in the #4 cylinder. That won't be all that difficult to fix but still, it's another problem i have to deal with.
So that's the problem, so they say, and there goes $200 in shop fees just to find out what it is... Oh well, whatever's best for my baby
