car broke dwn 15min ago??
iiCiHiAiiViiPii
Car: 1990 240sx and 1995 240sx
i was doing about 75 on the highway on my way back to my work. i noticed that it took alot of RPM's to get the car to move. every gear took alot. i was one exit away and all of a sudden my RPM's shot from 4500 to 5500 and then to 6000. so i pulled off the road and coasted to a stop. i waited a lil bit. popped the hood and it def smelt like something was burning. (maybe catalytic Converter) or something in the block. maybe head gasket blown. i turned the car back on after cooling it off and it would get in gear, but when i hit the gas and released the clutch, the RPM's just sky rocket. is my transmission slipping or my clutch slipping? or is it something else. please help i have no car and im bout to go to sleep at my work
Razi
Car: Moo
Sounds like a slipping clutch.
iiCiHiAiiViiPii
shouldnt the clutch have some kind of problems getting into gear. its still very smooth when i shift. i have noticed that when i shift up, the rpm's and the speedometer do not move at the same rate like they should. the rpm's shoot up and the car takes a while to get up to speed. i have my aftermarket flywheel in back seat and waiting on ebay for my clutch. i dont know if should replace the transmission. i guess ill just replace the clutch and flywheel and see if it starts up. if that dont work, ill try something else. any other suggestions
Razi
Car: Moo
If your clutch is slipping, I imagine it'd still get into gear just fine.
nicc_dett
Car: S13_240sx_92_SE
slipping clutch.no, it would not have problems getting into gear.perfect way to test it.. go like 30mph. shift to 5th gear. smash the throttle all the way down. and watch the rpm's just shoot up.
if that happens, you def. got a slipping clutch
iiCiHiAiiViiPii
yeah i have been driving around with it for bout 2-3 days now. it was very minimum. it did exactly that when i was driving it. now its to the point where i cant even get it to move. thanks for the help guys. i should be getting in the clutch in the next 2-3 days and i'll nock that out in bout 4-8 hours. just did my roommates last week. thanks alot guys!
iiCiHiAiiViiPii
you guys have any idea where the smell is coming from. is that just from the stress on the engine?
iiCiHiAiiViiPii
i think it might have to be something with my exhaust, cuz sounds like something is burning and it only happened when i was around 5k rpm's
Razi
Car: Moo
Smell of burnt clutch.
YOUNG240SX
Car: 90 hatch
new clutch time thats final
iiCiHiAiiViiPii
YOUNG240SX wrote:new clutch time thats final
that would be why i pulled off the road! and got a tow truck
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
you probably could have just limped it home instead of forking over money for a tow truck.
dusred
Car: Previous Q45 owner, 09 Corolla, Ford F250 Diesel truck
iiCiHiAiiViiPii wrote:you guys have any idea where the smell is coming from. is that just from the stress on the engine?
The smell of burnt clutch is unmistakable. I just re-did the one on my truck and it was $950.00
Cheaters.
iiCiHiAiiViiPii
i was 3 miles from work and couldnt get it to budge. didnt want to blow any thing. i would pay 150 dollars to have my car towed instead of paying for a new bloc. idk. i played it safe. if i were to try and drive that thing to work, which i couldnt cuz i tried, and i if i had ended up blowing something, im sure everyone would call me a dumb a$$ for trying to make it to work when it was obviously not acting right. just unfortunate. glad to know whats wrong wit it though. glad i dont need a new transmission.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
def better safe then sorry. your car didnt show any signs of slippage before this happened? you sure you dont have a leak somewhere between the master and the slave? just tossing some ideas out before you get that involved, just seems odd it would go out w/o warning. either way, you played it right imo. good luck with your fix.
